esox39
- Chicago, IL
I pulled the trigger today on a Transit Connect. It's a second service truck. What does everyone think about just installing the floor drawers for material and leaving the rest open for lager things?
If everyone drove the same vehicle.... you wouldn't be taller than anyone else:happyyes:
Only you can know the answer to that. It all depends on what type of service you do and what parts you normally stock. It wouldn't work for me, but neither would other guy's setups. What I have is still being tweaked, but I planned my shelving and layout out before I made my purchase. My dealership took care of the upfit and when I signed the papers it was ready for work.I pulled the trigger today on a Transit Connect. It's a second service truck. What does everyone think about just installing the floor drawers for material and leaving the rest open for lager things?
For anyone that already owns a Transit Connect, do you have pipe racks on your van? If you do what type, size and how are the setup on the van? I'm struggling with how I should approach this.
What if you need 1000' of 4 inch RMC?:lol:I have one of those bent ladder racks (drop down one side) and have a piece of 4" PVC mounted under it for pipe. I can carry 30 feet of 1/2" EMT, 30 of 3/4" EMT, 30' of 1/2" PVC and 20' of 3/4" PVC (IIRC...). If I need more/larger pipe for a job or wiremold or 8' tracks etc., it gets strapped directly to the rack. Ground rods fit inside over the bulkhead onto the front shelf along the side of the vehicle. In that respect, it's not a whole lot different than a regular E series van with a bulkhead that doesn't have a hinged door - you can't get pipe flat in the back of one of them either.
Logging truck?What if you need 1000' of 4 inch RMC?:lol:
Logging truck?
i usually keep 100' of 4" grc on the van for those quick jobs....
i never need anything larger for service calls... if i need 6" grc,
i call the wholesale house and get it delivered....
the real problem is threading and bending... the equipment
takes up a lot of room.....
I'd like to see if the roof of that van would support the weight of 100' of 4" GRC, if it does take it down the road and over a few bumps and see if it still supports it
The motor for threading and bending equipment may have more HP output than the motor powering the van
I had a job recently where I had to bring out 50+ wraparound fixtures, 10 ceiling fans, all the switches, receptacles, plates, plus ladders, a table (that comes in very handy vs. putting fans and fixtures together on the floor) and other misc. items needed to finish up this place. All that would never have made it in one trip in that thing, but my trailer was only maybe half full.
