zog
- Charlotte, NC
OK, you are installing a new range that is a 60 foot run.
I will be shocked if you can make a neutral poll on this subject. :grin:
we normally run 1 continuous 8/3 romex to our new home ovens...we have so much scrap (in varying lengths) i was thinking of making some spliced runs.....are there restrictions in the number of splices we can make??...
If the wire is new, it is new, if there is more than one piece of new wire in a run it is not an unprofessional installation.
Now anybody can stretch the case scenarios into the ridiculous and make it unprofessional in order to get a manipulated consensus.
Roger
No, I am trying to make this unbiased, you edited my poll to get the answer you want by adding senarios that have nothing to do with my question regarding the above quoted post.
So let me get this straight, you are asking specifically about four pieces of new wire, not three, or some other number and the reason for the splice(s) are unknown?
Roger
You have made it very obvious where you stand.
New wire of the proper length in a single section
4 pieces of scrap wire spliced together
I just want to see what is viewed as professional by the EC's out there.
So zog is this the poll you wrote?
And you see that as unbiased? :grin::grin::grin::grin:
Yes I have and I am not ashamed of my stance. I have enough confidence in my abilities and that a splice I make will not fail, and if there is a good reason to splice new wire I will.
Roger
Zog, the wire cost the same whether it is on one spool or multiple spools. :roll: Therefor, since splices add expense to the job, and if cost is a sign of a good installation, splices would be the way to go.
Roger
Is using scrap wire, multiple splices, in a new installation 60 foot run to a range seen as professional or not.
