Unfinished
resistance
WA
Hypo:
Lets say you have a home with a basement that is fully rocked (Sheet that is). All rooms have wood flooring accept a 12 foot hall that has a decorative concrete floor (Decorative meaning: They simply made the concrete look nice). Would you consider the hall unfinished--requiring it to have a GFCI protected outlet??? Note: This is not a situation I'm in, just curious
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
Hypo:
The floor has nothing to do with it being finished. The hall would not need gfci protection since it is finished.
iwire
Massachusetts
What I consider is unimportant, but in a resi app, the inspector here considers any concrete floor as unfinished: GFCI.
There is a large shopping mall we work at a lot and the local inspector requires GFCI protection for all receptacles on 'unfinished' cement slabs.
If there is no rug or tile we install GFCI protection.
resistance
WA
Interesting responses. Personally, I don't think we would have a problem getting it passed without GFCI protection. But (with focus on the location of the space), should we consider the concrete floor---seeing that concrete is conductive?
resistance
WA
Exactly where I was going. So, should we say that the floor dictates rather a space is unfinished when it comes to bare floor being in contact with earth?
iwire
Massachusetts
In the case of the mall I believe the inspector is going well past actual code requirements. We just do it and pass the cost up the chain to the customer. Not worth fighting it, when this inspector started in the trade he was wiring homes for cavemen. :grin:
resistance
WA
in the case of the mall i believe the inspector is going well past actual code requirements. We just do it and pass the cost up the chain to the customer. Not worth fighting it, when this inspector started in the trade he was wiring homes for cavemen. :grin:
lol!! Ic!! :d
jumper
How? Unless it's a local amendment, there's nothing in the IRC requiring floor covering:-?
Rcarrol, for the same reason Bob stated.
resistance
WA
Are houses built on slabs requiring GFCI protection for every receptacle?
Many questions can be raised related to my question. I'm really looking at the the purpose for a GFCI--as it relates to unfinished spaces that are most likely built on slab, with no floor covering (bare floor exposed). And why it's enforced as required for some areas but not others. I used the basement hallway to get around other mandates for a garage.
Interesting to me.
