CONTROL FREQ
- OHIO
CF, you obviously have extensive experience here, and there is very little you say with which I disagree. What I'll add is that there is an active movement to maximize energy efficiency at almost any cost. If I'm going to do a system design, there are numerous options which depend on the system requirements.
But, in general ... for a multiple "axis" system ...
fixed speed fixed displacement ... simplest, least efficient
fixed speed, variable (pressure compensated) displacement, next efficient, sometimes simpler system
fixed speed, controlled displacement, more efficient
variable speed, fixed displacement, most efficient
The HVAC guys, with SEERs of 14 and up, usually have gone the variable speed, fixed displacement route. When we do a centralized system, we often will have some energy storage (accumulators) with pressure feedback to a PLC to multiple HPUs (different pressures to minimize reducing valve use)
In industrial hydraulic pumps commonly available, I have a hard time beating an internal gear pump for efficiency. A fixed piston unit is darn good too, but there are fewer available. If I need over (ballpark) 200 bar or 3000 psi, the piston units come into significant consideration. Your recommendation of Vickers (Eaton) and Rexroth (Bosch) is good. While my own experience is heaviest in those, I'd add Parker to the list; they are a major line as well.
I regret that some who profess great (electro) hydraulic understanding do not show it. But that is not unique to any field ...
You know? That actually makes a lot of sense. I worked a long time with Desma punch presses (although we used them for injection molding) at any rate, they were fitted with dual output motors with a VERY dependable Bosch rotary piston pump on each shaft (one left---one right)... I never really saw any need for a VFD in that situation we ran a modest 1500-2000 psi. But last year, I was tasked with installing a pressure transducer, analog I/O's a VFD and programming a water transfer system to deliver more during times of high demand and less at other times. The system keeps a pretty steady 60 psi at all times with good ramping and no drops or spikes EVER. Thinking about it that way---I can see where in some applications a VFD for hydraulics would make perfect sense, and would be an excellent idea. I try to never be resistant to change and always be open-minded, sometimes 'tunnel vision' screws that up. Until someone opens my eyes a little with facts and real examples. Then I start to see oppotunities to use technologies I've already used, in a WHOLE new way. The efficiency never even occured to me, in the old presses I worked on, a VFD probably would've reduced oil temperature since during times of curing rubber in "high clamp mode" the pumps would not have been shooting oil through the manifold stacks at full bore back to the reservoir the whole time... Makes all the sense in the world. Not even my thread but I just now got a heck of a lot from it.
Thanks for the push my Friend,
Mike
