Came across a situation in residence where the fuse box, 30 amp hundred and 10 V, been removed and the load wires had been brought to another sorce panel but the neutrals were still sourced off the old number 10 bus bar
So the old fuse box was just the junction now but the neutral bus was still being use the neutral buss
Normally the only way your neutral can be separated from your line wire is in a switch leg but in any case the neutrals have to be kept distinct unless they're being sourced from that panel where the busbar is.
You cant just have a number 10 go into a box and pick up all the neutral.
So what is the code section on that if anybody knows off the top of their head? Thanks so much
In belief, man can do anything
