Not so surprised, people are always most comfortable with what they are familiar with. (I include myself in that)
That's a fair point. But I am not disagreeing on the basis of familiarity. I work with quite a range of voltages. We actually make products for the US commercial sectors so I'm reasonably familiar with supplies used there. And you are probably aware that Mrs B is from there with friends, family, and property. So it really isn't a familiarity issue for me. It's just simpler, in my view, to have a single voltage that feeds everything. And it avoids the lost neutral issue (seems to be a common theme here) potentially subjecting equipment rather greater voltages than their rating with the ensuing consequences.
Besoeker said:
No live electrical part should come in contact with people.
But it happens and that is a fact.
If we want to look at our work that way than over current protection is also unneeded because no conductor should be overloaded.
Not the point I was making. Of course there should be overcurrent protection.
Residual current trips (30mA) are used to detect earth leakage and disconnect the supply should there be current flowing where it shouldn't. Like through a person.
Besoeker said:
If a supermarket let that happen they would be under immediate investigation,and the management would probably face criminal proceedings
Certainly it is possible if they were negligent that they would be sued, it would be a almost unheard of occurrence for management to face any criminal charges over this in America. (I am not saying that is good, just the way it is)
Safety is being taken increasingly seriously here in UK. As it should. Employers have a duty of care and must take all
reasonable precautions to ensure the safety and welfare of employees. Failure to do so can and has resulted in criminal proceedings. As a result, all responsible employers bend over backwards to be seen to be doing the right thing. Sometimes to the detriment of common sense.
No, here in the US many more people are killed by 120 volt circuits than any other voltage .......... of course that has a great deal to do with the fact it is everywhere here.
And while 120 is not 'safe' it is in fact 'safer' to humans given the same set of circumstances.
For the same circumstances, I agree.
So as an engineer you are willing to say one voltage is alleyways the the best to use for the task at hand regardless of the load?
No. And I didn't. But for residential applications I see no need for two different voltages. UK and Europe manages perfectly well on single phase 230V for the vast majority of residences. A very few have 400V three-phase four wire but those are generally very up-market. The three phase is to cope with the total load. It's still 230V phase to neutral.
Personally I see no need to bring 230 VAC to a night light, that is much more power than needed.
It's no more power. And if you already have 230V....why would yo have a need to introduce a different voltage?
Here starting with the 2008 NEC we must use receptacles in dwelling units with shutters. It was a good change. :thumbsup:[/QUOTE]
