I'm trying to learn all the intricate rules with calculating load. Since I'm adding new space to my home, I thought this would be ideal. Our local AHJ will let me complete the wiring since I'm a EE and the homeowner. Not only that, but I would like to take the contractors exam as well and this will be good practice.
I have run through the load calculations twice. Once using all the rules from 220, parts I through III and another using the Optional calculations defined in part IV. The results are pretty different which is very confusing. So the question here is why?
A little more info:
I know that I will have to change my load center and meter center out as a result, but the differences are so great that I'm not sure which is best or safe to use without understanding why the NEC allows such different approaches.
With Parts I-III, I get a service load (Single phase 120/240V) of 227A for a 1940 sq-ft space with a 260 sq-ft basement-type space to be added that will be a workshop one day. For the workshop space, I just added lights and receptacles as it will not be livable or conditioned space as its actuall located in a large crawl space type area.
With the Optional Calculation, I get 160A.
This means I will either be installing a 200A load center or a 300A one? But which is right?
A little more info:
