rcwilson
- Redmond, WA
Solar Power
Solar Power
Several power developers are looking at solar thermal power plants in California and Arizona, using fields of parabolic mirrors that focus the sunlight on oil-filled pipes. The hot oil is pumped through a heat exchanger that makes steam to run a turbine to generate about 100-150 MW of power from a square mile of solar collectors. Tanks of salt solutions are used to store heat for evening operation and to increase the thermal cycle efficiency.
This makes sense in the Southwest where electrical load is highest when the sun is shining due to air conditioning. But it is expensive installed cost. I think the cost is less than a similar size solar cell facility.
Example of the size: each collector mirror has two large foundations. A crew pouring one foundation every 20 minutes, 24 hours a day, 7 days a week, can finish the work in 1-1/2 years. Every mirror has an aiming motor that needs to be wired and checked out, which will take about two years round the clock at 1 hour per motor.
Solar Power
