Your home /afci install?
jaylectricity
Massachusetts
licensed journeyman electrician
celtic said:
But then WHY....is there GFCI cordsets on dryers?
Obviously, to ward off a Darwin Award for a person....and as we both agree, does nothing for the BC.
So then WHY...can't the same be done for other products used in a home (as detailed above)
The GFCI is to protect personnel from faulty equipment or wet conditions. So hair dryer manufacturers are protecting the users of their product.
The AFCI is to protect the wiring in the circuit. If there are arc-faults in the walls, or in splices up-circuit from the receptacle in use, an AFCI cordset isn't going to protect anything.
sparkyjim
Dallas, TX
electricalperson said:
well if something is plugged in a receptacle and causes the afci to trip its not the breakers fault. the breaker is doing its job. get a new vaccuum.
i dont like it when people get mad when a breaker does its job. people always ask me to take GFCI's out because they keep tripping when they plug the christmas lights in outside
The vacuum's are the problem. One of the first ?'s I ask is " what type of vacuum do you own?" When they reply "Dyson", I know I'll be having issues.
don_resqcapt19
Illinois
retired electrician
The fact that the AFCI trips does not mean that it is the appliance's fault. Some equipment that is working properly and is completely safe, produce a wave form that the AFCI thinks is a hazardous arc. This is not the same as with GFCIs where, in most cases, there is an actual ground fault in the equipment that is hazardous that causes the GFCI to open the circuit.
celtic
NJ
jaylectricity said:
The AFCI is to protect the wiring in the circuit. If there are arc-faults in the walls, or in splices up-circuit from the receptacle in use, ...
Not disagreement here...
jaylectricity said:
....an AFCI cordset isn't going to protect anything.
However...
Well if the circuit is operating properly w/o anything plug in...but trips when an item is plugged in..where does the fault lay?
With the homes wiring or the appliances?
This is why I say:
Full home test before occupancy - then have the manufac.s provide AFCI protection on cordsets.
In the case of homes built prior to 2002 - AFCI protection isn't an issue?
Provide AFCI cordsets.
iwire
Massachusetts
First off let me say that I am no fan of AFCIs and how they seem to be pushed on us before they really work.
For the purposes of this post lets assume AFCIs do what there supposed to.
celtic said:
IF the big issue with AFCI protection is protecting the wiring from various installers penetrating the insulation....why not require a AFCI test procedure of the ENTIRE home before occupation?
It seems to me they are just as worried about things that may happen in the future. Say grandma decides to use a 16d nail to hang a picture.
Now the HO moves into a problematic free home...and let the manufac.s put the silly ends on their products.
The EC sells a safe product...the manufac. sells a safe product.
That leaves the circuit unprotected which goes against what seems to be the intent of AFCIs.
When we start getting into homes built prior to 2002, AFCI protection is non-existent. It may very well be decades before the home is re-sold and - in some localities - require various death defeating devices like AFCI protection. But in the meantime...what? Let 'em burn?
How is that different from all the homes that do not comply with todays code?
But then WHY....is there GFCI cord sets on dryers?
Still apples and oranges to me. :confused:
A GFCI on the appliance cord will get the job done.
An AFCI on the appliance cord will not get the job done.
celtic
NJ
So iwire, to be clear on your position:
Some protection is not better than none.
...and why the complete omission of kitchen lighting?
iwire
Massachusetts
And fully protected is better then some protection.
You seem to be saying we should never be required to protect the entire circuit and that the manufacturers should just do it on their end.
Well that will leave a much longer part of the circuit unprotected.
I have no idea but do you really think it will stay that way?
celtic
NJ
Not at all.
What I have been saying is:
If grandma decides to go postal with framing gun in her house...no amount of fail safes will prevent some damage to something...be it a piece of NM or a PEX supply line or the neighbor next door who forgot to put on his Kevlar leisure suit and helmet.
If an AFCI device every makes it to the marketplace...what sort of protection will it offer from grandma?
Type AC really isn't all that ;)
Now that everyone knows...no :D
iwire
Massachusetts
OK so the overcurrent protection might as well be done at the load end of the branch circuit.
I am done, I have no idea what we are arguing about. :grin:
JohnJ0906
Baltimore, MD
Yup, Dyson has been a big problem vacuum, IME.
SquareD also admits that some vacuums cause their AFCIs to trip (although they don't name brands.)
MF Dagger
Pig's Eye, MN
SEO said:
I would use them in my home. If you want to get rid of them submit a code proposal.:roll: :smile:
I seriously believe that there was some back room deal making that went on to get afci's brought so fully into the code so quick. And THAT is what my problem is with them.
SEO
Michigan
I think that you may be right!
