Adamjamma
- Jamaica and london
It bugged me so much I just sent them an email requesting more information on how it works.. see what transpires.
Dennis, I agree with Don. I look at your diagram and I see the "signal wires" that Panasonic Whisper Green exhaust fans use to control their plug n'play relays that change exhaust speed. Panasonic has two red wires, one of which is solidly connected to the neutral, the other of which is considered to be line voltage. . . except it is only an electronic circuit level line voltage that is shunted to the neutral through a standard snap switch, basically taking the logic state from signal voltage while open to zero volts. The circuitry uses the logic state change however it is engineered to.
The ZOOZ diagram, while labeled as it is, only shows a single traveler. One cannot wire a threeway that is described in 404.2 with a single traveler. . . therefore, what is shown in the ZOOZ diagram is not a Code violation.
I'll bet that the manufacturers of this are going to get push back from various members of the AHJ community until the language of the documentation becomes clearer.
If it is simply completing a loop then why is the neutral bonded? In a fault in the bulb or in the lighting circuit from another bulb you now would have fault current running through the switches.
better design would be to have the current run through the switches before coming to the dimmer, so the load side of first switch- the common- becomes the feed to the dimmer. But, perhaps this meets the exception for a loop, except I thought the loop was supposed to be kept from any fault conditions by ensuring the live to be disconnected before or at the same time as the neutral.
But that is not clear until you figure out that a note over the switch in the ballon tells us that we can use a normal one way switch, with the red to the one terminal and white to the neutral.How would that drive fault current though the switches? The red wire on the switch does not connect in any way to the loads served by the switch. It is part of the internal logic circuit.
Yeah, I think your wrong
connect your travelers as we normally do through the switches,
and then bring our ‘live feed’ back to the red wire position from the final three way common terminal. But all the switching would be in a loop system rather than live system... except it is using the neutral as one part of the loop.
Thus, if a fault occurred elsewhere on the neutral conductor, in another room for instance, fault current would be brought through the neutrals to the red wire position on the dimmer, until the breaker operated.
Dennis or Jumper, am I wrong here?
You don't need any kind of note to tell you that the red wire is not part of the supply to the loads. They already have a direct connection to the grounded circuit conductor. There is no reason to think the neural to the second switch is carrying any load current.But that is not clear until you figure out that a note over the switch in the ballon tells us that we can use a normal one way switch, with the red to the one terminal and white to the neutral.
thus, in a three way switching ( or four way ) system you would run the neutral as they show.. connect your travelers as we normally do through the switches, and then bring our ‘live feed’ back to the red wire position from the final three way common terminal. But all the switching would be in a loop system rather than live system... except it is using the neutral as one part of the loop.
Al, it seems to me that the neutral to the switch is fine but why not use a separate wire that is not part of the neutral to send the signal to the other switch? Seems like that would not raise eyebrows.
