Announcement
Collapse
No announcement yet.
How to ground a service panel NOT!
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Todays' service call: Home inspector said the main panel in the basement wasn't grounded properly.
    Click image for larger version
Name:	Just GroundI It to That Pipe.jpg
    #2
    I would say he is correct.
    Roger
    Comment
      #3
      Electrician pointed in the general direction of the water pipe and the helper was unclear on the concept?
      Comment
        #4
        I'm thinking the foreman said, "Clamp it to this pipe right here......."
        Comment
          #5
          Need to see the service to see what's going on. From your picture I agree with the missed the water pipe by that much, 99!
          Comment
            #6
            HI scores!
            ~RJ~
            Comment
              #7
              The other end is on the service neutral/ground bar.
              Comment
                #8
                Is that raceway still bonded if you remove the bonding jumper in question?
                May not be a grounding electrode but instead a bonding jumper for equipment grounding purposes.
                May still need additional grounding electrode ran if there is none already.
                I live for today, I'm just a day behind.
                Comment
                  #9
                  It's simply a bare ground from the panel to the conduit. The raceway goes directly to the panel. This is merely a redundant ground path. Does not attach to anything going to water pipe or electrode. I relocated it about 6" to the cold water pipe and verified the jumper at the meter.
                  Comment
                    #10
                    Answered my questions I guess.
                    Comment
                    Working...
                    X
