Announcement
Collapse
No announcement yet.
Sleeve Setting
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Sleeve Setting
    What would be the best way/procedure to set these sleeves in poured concrete slab? They are going in a telecom closet? Thank you!
    #2
    Unistrut supported to the for work or set on the metal decking. Depending on the construction type.
    Sent from my LGL157BL using Tapatalk
    Some people are like slinkies. They serve absolutely no useful purpose. But still put a smile on your face when pushed down a flight of stairs.
    Comment
      #3
      There will be metal decking.
      Comment
        #4
        Drill the decking and support them with strut laid flat on it.
        Comment
          #5
          The space between them needs to be at least 3x the size of the largest aggregate. Did the architects allow for that?
          Comment
            #6
            If it's metal deck then are you drilling a hole in the metal for each sleeve?
            Typically these areas of the deck are designed to accommodate what is shown in the detail.
            Rob
            All responses based on the 2017 NEC unless otherwise noted
            Comment
              #7
              so your asking about cutting metal deck? also how is the area or that slot accommodated for? thanks
              Sent from my SM-N960U using Tapatalk
              Comment
                #8
                Yes, if there's a metal deck are you drilling a hole in the metal to allow the sleeve to penetrate to the ceiling below or are they leaving a big open slot to accommodate the sleeves?
                Rob
                Comment
                  #9
                  Sometimes I wait and core drill
                  Comment
                    #10
                    well i wish i knew.
                    Comment
                      #11
                      that would be a lot more time consuming.
                      Comment
                        #12
                        And costly.
                        Comment
                          #13
                          This is the best way to do it. No muss, no fuss, and you just pack it all with fire sealant after the sleeves are set.
                          Comment
                            #14
                            One of your men need to be there during the rebar installation.
                            Comment
                              #15
                              So if the leave a slot how are the sleeves supported? I'm thinking you strap them to strut that would span the opening?
                              Comment
                              Working...
                              X
