Announcement
Collapse
No announcement yet.
Concrete Inserts
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Concrete Inserts
    Hey guys, When you are hanging racks from slab which inserts are you using for the threaded rod for both poured slab and existing where you have to drill. Thanks.
    The blue banger are pretty good for steel deck poured slab.
    http://www.isatsb.com/blue-banger-hanger.php
    #2
    We use the 1/4+3/8+1/2 blue bangers (the one in the middle) for wood form construction and yes they work great. Just spray a big circuit around them with spray paint so you can easily find them after the pour.
    Rob
    All responses based on the 2017 NEC unless otherwise noted
    Comment
    Working...
    X
