Announcement
Collapse
No announcement yet.
220VAC single phase to 380VAC 3phase for Lathe/Milling machine
Collapse
This topic is closed.
X
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Hi
    I have a question, is it possible to use a single phase 220VAC supply and use an inverter or VFD to convert to a 380VAC 3phase power, to run a milling machine and a lathe separatly ?- How much current will the single phase be drawing, the lathe has a 380VAC 5HP motor and the milling machine is a 380VAC 3HP motor, also if there is an inverter can you wire it up directly to the machine as if it was natural 3 phase 380VAC input
    please post links to inverter or VFD's if possible
    Thanks
    #2
    I am closing this thread, in accordance with the Forum Rules.
    This site is designed for:
    Comment
    Working...
    X
