marmathsen
- Seattle, Wa ...ish
- Electrical Contractor
What are your thoughts on using GFCI breakers instead of GFCI receptacles?
For reference I'm a residential electrician. For years we installed GFCI receptacles where required, but as the requirements for AFCI protection got expanded we started using dual function AFCI/GFCI circuit breakers where both were required for a given receptacle. We soon after decided that locating ALL of our AFCI and GFCI protection (including GFCI only breakers) inside the panel made for easier troubleshooting for the homeowner and simplified installation, so no more GFCI receptacles. We've been doing this now for a few years, with very few exceptions where we feel a GFCI receptacle is more logical.
My question is if anyone has an opinion on this logic. Are there concerns of the GFCI not functioning as quickly or accurately when it's 100'+ away from the receptacle? Obviously if you're a landscaper outside and you trip a GFCI with your tools and no one's home to reset the breaker, that'd be annoying (we've discussed this a lot in my company).
Just curious. Thanks.
Rob
Rob
