Announcement
Collapse
No announcement yet.
What fuses for motors?
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    What class & type of fuse would work for the following:
    200HP / 300 amp fuses
    150HP / 225 amp fuses
    125HP / 200 amp fuses
    100HP / 150 amp fuses
    60HP / 90 amp fuses
    40HP / 60 amp fuses
    20HP / 30 amp fuses
    15HP / 25 amp fuses
    10HP / 20 amp fuses
    5HP / 10 amp fuses
    3HP / 6 amp fuses
    1HP / 3 amp fuses
    All motors are 460 volts 3 phase
    Do I size the wire to the fuse, or do to the motor's FLC?
    1.15 and over service factor means fuses are sized at 125%, but under 1.15 I use 115%, correct?
    #2
    Wire is sized to 125% of full-load current in Table 430.250
    I thought we went over using fuses for running overcurrent protection a thread or two back. The 300 amp fuses may not allow a 200 HP to start. In that case a 500 could be allowed. Do you really want to have 500 amp fuses providing running overcurrent protection for a motor that should draw 240 FLA?
    430.52(C) (1)(b)
    Tom
    TBLO
    Comment
      #3
      Even when the fuse is acting as the overload and larger then the FLC?
      [QUOTE]
      430.52(C) (1)(b)
      There has to be fuses out there that can handle inrush and also provide descent over current protection- I'd think.
      FWIW, I came across these:
      https://m.littelfuse.com/~/media/ele...tion-guide.pdf
      http://www1.cooperbussmann.com/pdf/6...65a95db302.pdf
      Comment
        #4
        My experience usually ended in single phased motors. Under 5 HP are disposable, depending on how critical they are to your process so the cost of a NEMA starter may not be warranted. IEC starters are a different story.
        Fifty horsepower motors are in the neighborhood of $3,000 and you will need at least ATL start. Why skip the overload relay?
        Tom
        TBLO
        Comment
          #5
          The way I figure it fuses are already required. So why use separate overloads?
          Comment
            #6
            I can't read the details, not that it matters.
            You are the EE, if you are happy with fuses, go for it.
            The Bussman and Littelfuse reps will be glad to take your call.
            Tom
            TBLO
            Comment
              #7
              But- I am embarrassed to admit that I don't know the inrush properties of 3 phase induction motors for various horse powers when switched on at various points in the sine wave, when there is a momentary "blink" and when there is residual magnetism still in the iron.
              I know transformer inrush varies based on those 3 factors, and, I'd imagine its the same for motors.
              Comment
                #8
                FWIW, manufacturers frequently do it:
                https://youtu.be/Z7e4-KE-kWM?t=148
                Not sure how they get away with a compressor though- don't these stall when power is removed and re-applied?
                Comment
                  #9
                  But, only worst-case numbers matter, right?
                  Master Electrician
                  Electrical Contractor
                  Richmond, VA
                  Comment
                    #10
                    Correct- however- I don't know what those are.
                    Comment
                      #11
                      Impedance of source along with supply conductors (feeders and branch circuit conductors) can effect how much surge current may flow when first energizing a motor. More impedance will be current limiting, however will also result in less initial motor torque - soft starters intentionally do this.
                      I live for today, I'm just a day behind.
                      Comment
                        #12
                        You could look at Table 430.7(B).
                        I'm sure you know the code letter on each motor nameplate and they will always be the same.
                        Tom
                        TBLO
                        Comment
                          #13
                          Can we assume infinite bus?
                          Comment
                            #14
                            But is it the same as inrush? My understanding is the you first need to magnetize the iron before the current drops below the I2R impedance of the windings which is very low.
                            NEC tables link:
                            http://www.superb.org/power/nec%20tables.pdf
                            Comment
                              #15
                              Certainly, but will result in larger numbers.
                              Master Electrician
                              Richmond, VA
                              Comment
                              Working...
                              X
