mbrooke
Batteries Included
- United States
- Technician
You would typically be mistaken with this thought. For example, if the motor is not loaded substantially, the current in the remaining phases may not increase significantly.
In that case neither would heater catch it. One phase opens- if the remaining two phases pull more current they either cause the soldier to spin the wheel tripping the starter OR the fuse link melts on one phase dropping the motor.
Some 60 years ago the NEC started requiring running Overload protective devices in each phase, for this very reason.
[/QUOTE]
Correct, for open phase conditions outside the structure:
http://www.cooperindustries.com/cont...le-Phasing.pdf
I know I'm being a hard head, but in so far I can't find any case against fuses providing overload protection. To be frank with everyone, I've never even fully understood the purpose of heaters. I always wondered why they didn't just sell a standard molded case breaker with the thermal and magnetic trip slightly tweaked at the factory.
