Latest addition to "Wall of Shame"
Isn't that why they make compression connectors and couplings? :D
It's the difference between a journeyman and a hack!
Not arguing the type of connector, arguing the ability to perform the job in a workmanlike manner....that thread job is hack by any measure!
HACK Doesn't even begin to describe this ignorance. Recommend that the guy contact a QUALIFIED Electrical contractor in the area.
Are you fixxing this trash?
Um guys, look closer..that appears to be EMT that someone threaded!!
Some of us old guys can't look any closer.... my nose is leaving spots on the screen and I still can't tell.
If I was sitting in the witness chair at a trial, I'd honestly have to say it's not EMT. But that's just my ancient eyesight.
358.2 Definition.
Electrical Metallic Tubing (EMT). An unthreaded thinwall
raceway of circular cross section designed for...
358.28 Reaming and Threading.
(B) Threading. EMT shall not be threaded.
358.100 Construction. Factory-threaded integral couplings
shall be permitted. Where EMT with a threaded integral
coupling is used, threads for both the tubing and
coupling shall be factory-made. The coupling and EMT
threads shall be designed so as to prevent bending of the
tubing at any part of the thread.
358.2 Definition.
It's all good, the antennas I spoke of also use the EMT as the supporting means and a raceway for a cable. :cool:
I do not think the NEC applies to that application, I just wanted to point out that EMT can be threaded and come out looking good. We have to screw the threaded EMT into a conduit LB.
Heard tht the Europeans had something like IMC light that they threaded, but not as light as EMT. Anyone know something about it?
I didn't get to respond yesterday because I was out of the office. MX, you are correct, it is threaded EMT done by a "qualified" individual. The position is for qualified individuals, the person in the position...
Oh good, I thought it was just me.:cool:
Unfortunately, it's just you two.:D
