Inspectors job
the last 6 years has been the best job i ever had, steady paycheck, plenty of time off, 8:00 to 4:30, no weekends, 1/2 in the field, 1/2 in the office, 401K, the first 22 years were not as pleasant, can you guess which one is the inspector job
This is awful inspectors reading this string are certain to collapse in the coner and assume the fetal posistion.
The code is always a fight of langauge Vs intent.
The CMPs are not always certain of intent. There is a significant amount of compromise on panels, read the ROP and ROC, unfortunately the application of the code is not always black and white ( you may think it is but my experindce is it is not) I think the Code is written (to some degree) to allow for such interpertations and this will always cause disagreements between the installer and enforcer.
As I mentioned earlier most jurisdictions have appeals processes. when this method is exercised it weeds out bad inspectors and or contractors.
All of us are unique in are own way and we all have specific experinces. It is not easy to view each installation with a fresh eye some times the EC is catching the inspector after dealing with one or several installers that some would not let carry their screwdriver.
Don't paint every inspector with the same paint brush. They should not paint each installer with the same paint brush either.
YA I'm an inspector and some days I'm not as good as I should be. But there are contaractors out there not as good as you guys appear to be.
how many times have you been at a meeting or seminar and 1 code section gets 3 different interpretations and 30 minutes of debate and still have the room divided on whats correct
You will never find a post where I have said inspectors have it easy. :smile:
But there are contractors out there not as good as you guys appear to be.
No doubt there are a ton of bad contractors.
That said I still fear hearing inspectors talk about intent.
one section that comes to mind and had many, many pages of debate was SER cable used underground in conduit, it is resolved now because the 2008 prohibits it
I had no problem with it, :D it is a perfect example though.
Looking at the SER issue the words where not there to prohibit it and the CMP must have felt the same way regardless of the intent all along. I would say that the change proves the point I had been making that it was not directly prohibited. :cool:
Understandable
Langauge is enforced.
But
Afci's (dwellings)
A laundry is not mentioned in 210.12(B)
Does this area require AFCI??
what does similar mean?
what was the intent of the CMP when it actually accepted language to require the entire dwelling to AFCI-ed and then omiited bathrooms, kitchens, unfinished areas and outdoors.
and we would still disagree, but the 2008 ruined that, no more SER underground posts, i kinda miss them
This is awful inspectors reading this string are certain to collapse in the corner and assume the fetal position.
I do not think so, there has been no slander against inspectors, some questions and some facts, but no harm is meant against an important part of our profession.
As much as it pains me :D (kidding) I have to agree with iwire that intent has nothing to do with it. The AHJ has the job to interpret the rules not guess "what are they trying to say here?"
As far as AFCI in the laundry it is up to the AHJ to decide if the laundry is a similar room because that is what the code says. If they had intended it to say something else...............they would have.
(added) Just like if they intented receptacles within 6ft of the kitchen sink in dwelling units to be GFCI they would have SAID so.... yeah still can't let it go.....
Areyou saying the language in the NEC states that a laundry is similar to DR, Bed Rooms, Living Rooms, etc???
ore is it your intent to say that a laundry is similar to a kit, bath unfinished area or out doors. These are the things that drive electricans bananas
Don't read into what I intended to say just what I said. :D
The code says what is says brother not what anyone thinks it says. So if the AHJ thinks there are rooms similar to those listed they need to be AFCI protected because that's what it say.
I disagree here as well, the job either meets the words in the code or it does not. An inspectors personal beliefs about the intent should not enter into it because really the inspector does not truly know what the CMPs intent was.
Well in my opinion there's at least some parts of the Code that are intentionally ambiguous. And there are lots that aren't. But that still lends itself to interpretation on occasion. And with a pseudo-appelate system in place then it can work its way up until it reaches someone who DOES know what the CMP's intent was. I think at some point in the recent past, one of the top electrical inspector guys in our state was on a CMP.
One of our apprenticeship teachers is the County electrical inspector. He's good, and fair, and he gives us the inside scoop on the inspector world. I agree with you on the police officer vs. judge thing, but it's kind of a matter of the inspector's personality. If he's a jerk with a complex then he might measure every single hole you bore to make sure your wire is 1 1/4" back. Otherwise he might work with you instead of against. The Code can't anticipate every scenario and so it sometimes needs to remain vague, in which case the inspector, usually representing the AHJ around here, needs to objectively decide if you're compliant or not.
Side note: My wife and I just saw the new Star Trek movie and it was awesome.
4 electricians will find 5 ways to do something but the NEC says whether it is code compliant or not. While often misunderstood I do not think there are as many grey areas as people like to think.
Actually you would be surprised. If I can dig through this pile of papers on my desk I'll see if I can find the examples that were given to us at the last Southwestern Section Meeting of the IAEI. Really, had a whole two hours on "Grey areas in the NEC". We were even told that some are in there on purpose.
As for being an inspector vs an EC. I chose inspection not because I was "washed up", but simply because I wanted the security for my family. I've been with the city for almost 20 years now, I work 7:00-4:30 four days a week and then I work 7:00-3:30 every other Friday and I get every other Friday off. 11 paid holidays. 7.95 hours of annual leave every two weeks, comp time vs overtime if I chose and holiday comp if a holiday falls on my day off. 457 plan with city contribution. Retirerment paid for entirely by the city. Boot allowance. Tuition reinbursment. Training paid for by the city. Health, vision, dental insurance for my family paid for by the city. Truck provided by the city. We don't make $100K a year here, but I'll be in the $75K range this year.
Like they say, not bad work, if you can get it. :smile:
Oh yeah, and I also don't like inspectors that don't know what they are talking about, but no more than electricians that are the same way.
I guess I don't get it. Isn't that the inspector's job? Why is someone a "jerk with a complex" for doing something that is their job? I'm not involved with inspections, so maybe I just don't understand (but my parent's house did have a fire that was caused by a nail placed through a wire - I wish that hole was measured).
Well said. I have no problem with a tough inspector. Either I did it to code or I didn't. If I didn't, it's his job to try to find it. Cheap insurance is the way I look at it.
