Hehe, my boss might have charged about $150 total, which is why we're almost out of business...
I'm going to ask everybody for opinions on that ground screw while we're at it - The new 14-2 is tied in to an old romex w/out ground. What is your common practice for using ground screws in this situation? If you do use one in the pancake, another electrician may assume it's grounded when in fact it's not. If you cut the ground wire off (I've done that when replacing two wire to a T-slot receptacle so that no one installs a three-prong outlet without rewiring) then if the light does get rewired and your splice is pretty far away, the next guy will have to rewire it anyway instead of just splicing into your wire. Secondly, using a ground screw in the attic could confuse someone as to which is the feed (assuming the wire runs off to who knows where) and they could try tapping into that line, hooking up a ground and carrying the problem further.
In my humble opinion, it's safer to cut the ground wire back so you don't mislead anyone into thinking they've got a ground when they don't. Your opinion?
