PetrosA
- Lancaster, Pennsylvania
I think I've changed some outlets after you, wondering why my grounds are tucked behind the metal box, or cut to a 1/2inch in the box.
Now that's uncalled for and rude. I asked a legitimate question that anyone who does enough old work will come up against. You will have the option to either charge such a high rate for the work that the customer will choose to live with the danger, or you can weigh options and find a safe, "next best" solution.
Let me ask you this, if that had been a two wire romex, would you have walked away from the job, or charged possibly $1000 or more to rewire the light from the panel (let's assume worst case scenario top landing in a 2 or 3 story victorian, not balloon framed, wallpaper and with three way switching)? Did you check the BX for ground? Are you sure it wasn't tapped with a porcelain grommet into knob and tube somewhere? (Judging by the age of the insulation, it could have been).
