westinghouse load resistor
electricalperson
massachusetts
when i was in school we had old westinghouse load resistor banks. you would flip knife switches to various posisions to get different resistance readings when we were playing with DC and simpson multimeters.
does anybody know if they still make a load resistor setup like this to test circuits with?
im thinking i can use it to put small loads on circuits to troubleshoot tripping arc faults or voltage drop on long runs
It's sounds like you went to a pretty good school. I remember when I was in school the texts and teaching was great but the hands on was lacking. I used to do some pretty cool tests back at the apartment after school. I used to scared my new, young wife to death some times :D. So may tripped breakers and resistors on fire :D
GOOD TIMES!!!:D
Ah....I miss those good times.
we used to use just DC power in the lab where we got to use those resistors and simpson meters. we had small DC generators that we were coupled to a DC motor. we would put power to the motor and once it was up to speed we would switch power to the DC generator and it would run itself
I don't think so, Tim. :cool:
Coast down slowly, maybe. Perpetual motion, nu-uh.
The load resistors you are talking about were most likely part of a wye/delta starter. Years ago I made a small load bank utilizing these.
I like to use something that makes noise, like a hole hawg or shop vac.
But be careful on MWBC's...you might fry them (or a TV) if you lift a neutral!
its possible i dont really know where they came from
they were really old and very dangerous to touch when the power was on since all the blades were exposed and the resistors were exposed in the back
i dont remember the voltage we used
