mike abbott
- Ohio
For what reasons would a customer or a contractor choose the added expense of GRC vs IMC in a factory?
In addition to what others have said, most non-electrically-oriented customers aren't even aware IMC is an available option. I'm not a proponent of the concept, but in many instances you could probably install IMC instead of RMC and they wouldn't know the difference.For what reasons would a customer or a contractor choose the added expense of GRC vs IMC in a factory?
I can tell you around here, there are a lot of electricians who have never heard of IMC, let alone know what it is.
But, it's in The Book (Art. 342)........
I agree, and you have to be very careful with the field cut thread depth on the 1/2 and 3/4 sizes of IMC. It is a fine line between getting the threads deep enough to thread into conduit bodies and keeping them shallow enough so that the pipe does not break off at the threads with a small amount of pressure.IMC isn't made with the best steel.
It is not the best to try to thread.
I would pick GRC over IMC any day.
(IMC has a different OD from RMC)
IMC has a larger interior diameter than RMC but I believe that the OD is the same.
How does IMC compare to rigid and EMT as far as corrosion resistance? I work in a corrosive environment where EMT deteriorates quickly, but not everything has to be as heavy-duty as rigid.
-John
What's IMC? Some new forum jagon? :grin:
