GRC vs. IMC
How does IMC compare to rigid and EMT as far as corrosion resistance? I work in a corrosive environment where EMT deteriorates quickly, but not everything has to be as heavy-duty as rigid.
Sounds like a perfect application for PVC.
If it's subject to that kind of damage in a Class 1 environment, I'd be voting on rob roy. Pallet jacks, fork lifts, etc., in the area, to heck with sch80:cool:
Or use aluminum rigid. It's a pain to work with, with it's probably not as bad as rob roy. Depends on what ype of corrosive environment you have I guess. We use aluminum rigid around cooling towers, but I'm sure there are some atmospheres that will attach aluminum as much as zinc and steel.
I just installed about 400' of 1" IMC. First time I had ever used it and it seemed very easy compared to RMC. Heck of a lot easier to bend at least. I guess my only concern is that it doesn't feel like it is a tight fit in the couplings even though the threads are bottomed out. I'm a little concerned about water-tightness. Should I be?
My experience was that it is much harder to bend than is rigid. As far as water tightness, conduit couplings have straight threads and are not water tight.
