- New Jersey
- Journeyman Electrician (retired)
I just call them switch legs.![]()
Me too. This is done all of the time, as mentioned, for ceiling fans.
I could be wrong but I always thought it was pretty common practice to use white as a hot in that situation and the others as switch legs. ............
.....If you mark the white wire in the switch and jbox above ..........
Using the white to feed switches isn't 'pretty common practice'. It is a Code requirement.
'If' is not an option. Reidentification it is also a requirement.
2007.(C)(2).
