kbsparky
- Delmarva, USA
I have encountered a situation where there appears to be some concern expressed by a homeowner.
A circuit originates from the main distribution panel (actually a sub-panel) with type NM cable, then goes underneath the house in a crawl space. In this crawl space, it terminates in a junction box, and then emerges with uf cable. This wire is laid on the ground until it disappears under the foundation where it remains buried for 20 feet or so feeding an outside shed. From the outside, you can't see the wire at all.
The owner had some surround-sound folks over to install some remote speakers for their new entertainment system. While under the house installing their speaker wires, they encountered this piece of uf, and then told the owner that there was some "high voltage" lines just lying there, and that was a hazard.
I had a look at it, but do not think that is any unusual hazard per se, since type uf wire is rated for outdoor use, and lying on the ground should not pose any. Now if it were type NM cable I might have been concerned, but not uf.
Now those owners are paranoid about these "high voltage" lines being under their house.
Do you think that I should offer to fasten the lines to the underside of the house, instead of leaving them on the ground? Would that make the presence of them any less hazardous? Should I tell the homeowner that their walls are full of "high voltage" lines, and anyone cutting holes in the walls would be at risk for shorting them out, or starting a fire? :-?
How would you handle this?
