- Chapel Hill, NC
- Retired Electrical Contractor
So a wire that is rated for direct burial can't be in contact with earth? IMHO, a dirt crawlspace with 2' clearance between bottom of joist and dirt is not an environment where I would consider a UF subject to damage since there would have to be an extreme need to even venture into it. A 6" flex duct would make it completely impassable to any adult. Aside from the danger of encountering something nasty like a Fiddleback, poisonous snake or rabid rodent, stapling the UF or drilling the joists is going to be next to impossible in that space, and I would say that UF is just the thing for those conditions.
Did I say UF cannot be in contact with the earth? No I did not. If the wire is in a crawl space where it must be fished because of the lack or space then I think we have a different story then what the op has written. If you can crawl under there then it is subject to damage.
The 2008 NEC, in fact, requires that smaller wires than #8 cables must be run on running boards or drilled thru the joists. 334.15(C)
Twoskins-- I still think you are dead wrong.
