We are having a debate about what type of clothing is required to work on PLC. Given a PLC panel with 120V IO, fused at 5 amps. From what I see in NFPA 70E 130.7(c)(9) to do live voltage testing I need to have a uniform with a arc rating of 4. Our electrcial folks have no problems with this as our standard uniforms are FR. The rub is we have other groups on site that work on the PLC's (instrument, analyers and controls system group). I'm telling them in order to work on the equipment they have to have the proper rated clothing or shut if off. The debate is why do they need arc flash rated clothing / protection when the arc flash hazard is below 1.2 cal/cm^2. I would appreciate your opinion.
