crimp connectors for grounding conductors
  • I use the listed tool
    Votes: 19 25.7%
  • I twist the wire with my pliers and crimp with my pliers
    Votes: 5 6.8%
  • I use the klien tool
    Votes: 17 23.0%
  • I will use any tool I can get my hands on
    Votes: 1 1.4%
  • I dont use crimp barrel sleeves
    Votes: 28 37.8%
  • I use my teeth
    Votes: 4 5.4%
  • Total voters
    74
Do you mean this?
Greenies OK for commercial work?
The green wirenuts are fine when you have only one recep or switch to ground, but since we have to ground all switches, crimpies are the way to fly for multiple switches or recepts in a box. Question - does your AHJ allow greenies in commerical work? I've been told it's against code for commercial, but resi is OK. No company I've worked for (commercial) uses them. As to the tool, I use the Klein crimper tool - which is a 'listed' tool I guess (?).
Leave it long at loop from device to device.
Why would a listed wire connector be OK for residential work but not commercial work?
We had a helper on a big commercial job one time that used greenies to twist together the hot wires on some 277V circuits.:mad:
Guess who found it before we did - the inspector.:mad::mad::mad:
I've never purchased Greenies since.
Do you mean this?
I worked for a guy when I was an apprentice that had us use these with the plastic snap on caps for all splices except for fixture connections.
For the fixture connections we used a connector that was brass with a setscrew and had a screw on cap. I think they called them Marr connectors.
I don't use them, but I have re-used them when they were already there, and sqished them with my Kleins.
crimp in commercial
crimp in commercial
Crimp bonding is not common in most commercial unless there is NM in the system. Crimping 410's are plain difficult using a Buchanan on stranded wire in commercial that does not use a separate grounding conductor as found in Romex.
As far as using greenies in residential, making up the bonding jumpers takes more time to makeup EGC connections to terminals in multiple switch outlets where one crimp is quicker. I guess the question I ask...is why would anyone use greenies on a commercial job where the conduit is the basic EGC? rbj
