crimp connectors for grounding conductors
  • I use the listed tool
    Votes: 19 25.7%
  • I twist the wire with my pliers and crimp with my pliers
    Votes: 5 6.8%
  • I use the klien tool
    Votes: 17 23.0%
  • I will use any tool I can get my hands on
    Votes: 1 1.4%
  • I dont use crimp barrel sleeves
    Votes: 28 37.8%
  • I use my teeth
    Votes: 4 5.4%
  • Total voters
    74
Thomas and Betts "stakons" are copper, they are "listed" and they do not require the Buchannon 4 point crimper to use them. The actual listed tools for the use of "stakons" are two point crimpers found in the Thomas and Betts catalog. If using a solid wire, twist it first before crimping and you get every bit as good a crimp as a wire nut. If somebody cannot get a barrel tube to crimp on properly, I would suspect they are not qualified to install wire nuts either.
i use the crimp connectors with the listed four point tool. I really like them. It makes a good solid connection and takes less room in the box.
