Thanks. it is a 16x80 mobile home with most modern luxuries. I see 2/0, was just thinking 4/0 alum. would be cheaper. I'm thinking copper will be a better way to go anyway. So I'll stick with 2/0 copper for a 200 amp feeder, what if she added a small shop later on?I maxed every thing out on my software and came up with 103 amps for a older lady in a mobile home. That's 24,690.50 va, 120/240v, 1w/g, 200' length one way, comes out at 102.88 amps. Wire size 2/0. But hey if you want to pull 4/0 go for it, but 250's are out of the question.
P.S. This was calculated on a 16x80 mobile home. With all the modern luxuries.:wink:
4/0 on 400 amps,,,,yo're gonna burn something clear..,,,,,,,,probably the house
Carefully computed?????? they never set foot in a house,,,,,,,,they feed per your service,,,,,
you can't put 400 amps on 4/0 alu no matter what.
The odds are you won't find one, because the bus stabs are probably not rated for more than 100 or 125a.Is there a 200 amp breaker small enough to fit like a 100 amp double pole would, as there is not provisions for a main.
Again this came from home depot, square d, NEMA 3R, 200amp 120/240v, 12 space with meter socket atop already attached from factory, aluminum bussing but no lugs to feed through to house panel. So what is the best route to make this work?
Like Larry said, 100-125 is usually the max although you may find a 4 pole 200 amp breaker. I'm not familiar with Homeline so I don't know. A couple other options are to reduce the feed to 125 amp(somebody mentioned the calculated load is only 103 amps?) or use a different panel with feed-thru lugs.
anyone, ease my mind about the wire size?
