I have seen Class 2 12V lighting circuits (the low-voltage side) run on Romex or even on BX. Is this really permissible? I can't find any language in section 725 which would seem to allow the use of any cable types other than the CL/CM series for Class 2 wiring outside of conduit.
I keep a spool of 12AWG CL3R around for high-wattage speaker wire and other low-voltage, high-amperage applications, since by the table of substitutions in 725.154 it will work for almost all of them. But this does seem a little silly if I could just use 12/2 Romex. I cannot find any language allowing this, so I think it is not permitted -- am I wrong?
