No. To the contrary, you have not made any points. You have simply repeated the statements and your only supporting argument has been that everyone is wrong except for David.
I beg your pardon? I HAVE made several points. However, unlike you, I have provided descriptions of the reasoning that I have applied to the points that I have been making. You have said several time that "electrons don't care where where the potential comes from" in arguing that the potential source and voltage drop are the same thing. "Electrons don't care where where the potential comes from" is not a reasoned argument. Tell us why you believe that. Provide some type of evidence for your assertions (I'm still waiting to hear where I am missing that minus sign.) Provide an example to backup your assertions. I have tried to do that in each of my post, but you seem to make statements and expect us to accept them as fact.
And as far as the argument "that everyone is wrong except for David." Please, PLEASE show me one example in all of these posts where I have made such an argument. You should provide evidence for this statement, just as you should provide evidence for your technical statements! In post #291, I said "Rick, brilliantly said!" and "The thought that occurred to me when pondering this is the
exact same thought that
you expressed above." How you can read that and then make that statement that I think "everyone is wrong except for David" is beyond my comprehension. Your statement, quite honestly, is petty and mean-spirited. You, sir, are a cur.
Which comes first (i.e. chicken or egg
a) Does the voltage across a resistor cause the current through the resistor?
OR
b) Does the current through the resistor cause the voltage across the resistor.
You again, are not understanding my argument. I have argued that a potential source is required for current to flow in a circuit. It does not matter what that source is, but there must be a source. The potential source IS what CAUSES the current to flow in the circuit. Let me try another description of this and another example. I will enlist the help of the Navy (Basic Electricity: Prepared by the Bureau of Naval Personnel,) since I read something in it's definition of KVL which caught my eye. They stated KVL as follows: The algebraic sum of the instantaneous emf's and voltage drops around any closed circuit loop is zero. (In many cases, you see KVL expressed as the sum of the "voltages" around a close loop = zero.) I found their use of "emf" interesting. They define "emf" - electromotive force, as the "force that causes free electrons to move in a conductor as an electric current." This is the same reasoning that I have been arguing. It is the "potential source" or the "electromotive force" that causes the current to flow.
Let me try one more example to explain my point. Imagine a 12V potential source with terminals brought out and labeled as A & B. The "open circuit" potential difference from A-B would be 12V: Voc@ab=12V. The "potential" for current to flow between A and B presently exists in this network, we just need to complete the circuit. If we add a 12 ohm resistor between A-B, we complete the circuit and 1 amp will flow through the resistor (and there will be a 12 volt "drop" across the resistor.) By inserting the resistor and completing the circuit, have we ADDED or REMOVED any more "potential" into the circuit? No. The "potential" for current to flow between A and B was provided by the potential source. The "potential" for current flow existed in the network prior to the resistor being added. Now lets consider adding a second 12 ohm resistor in series with the first 12 ohm resistor between A and B. There will now be 0.5 amps flowing between A-B and there will be of 6 volt "drop" across each resistor. Have we ADDED or REMOVED any more "potential" into the circuit? No, we have not. The "potential" for current to flow that existed between A and B in the "open circuit" is the same "potential" that causes current to flow in the circuit with one resistor, and the same "potential" that causes the current to flow in the circuit with two resistors. And the "potential source" alone has provided that potential.
Whether you realize it or not, when you claim that voltage drop and voltage source are not the same, you have unwittingly, undermined Norton and Thevenin. Even though you would like to prove yourself to be correct, to do so would disprove Norton and Thevenin. Since these two are just theorems at this time, they are neither proven nor disproven, and as such, your argument can neither be proven or disproven--hence, you are arguing semantics. To the contrary, you have just demonstrated that you are arguing semantics. If it doesn't matter how/why a voltage difference exists, you have contradicted youself that a voltage source is different from a voltage drop.
Again, you make a statement, but you offer no evidence to back up your statement. WHY have I undermined Norton and Thevenin? Provide at least SOME explanation as to why you believe this to be true. Thevenin says "Given any linear circuit, rearrange it in the form of two networks A and B that are connected together by two resistanceless conductors. (If either network contains a dependent source, its control variable must be in the same network. Define a voltage Voc as the open-circuit voltage which would appear across the terminals of A if B were disconnected so that no current is drawn from A. Then all the currents and voltages in B will remain unchanged if A is killed (all independant voltage sources and independent current sources in A replaced by short circuits and open circuits, respectively) and an independent voltage source Voc is connected, with proper polarity, in series with the dead (inactive) A network." (per Hayt and Kemmerly - if you have a different statement of Thevenin's theorem, take it up with H&K, not me.)
So how has my claim that voltage drop and voltage source are not the same undermined Thevenin? It seems to me that in the example above with the 12V potential source and 12 ohm resistor, if I divide the circuit into two networks (network A will contain the potential source, and network B will contain the 12 ohm resistor) then the Voc per Thevenin will be 12 Volts. If I then kill network A (short out the 12V potential source) and insert a new voltage source Voc in series with network A, then the currents and voltages in network B HAVE remain unchanged. So how have I undermined Thevenin?
And if I have argued that a "potential source" provides the potential for current to flow in a circuit, and that "voltage drop" is the result of current flow in a circuit, and that it does not matter where the "potential difference" (created by the "potential source," and not to be confused with "voltage drop") comes from (it could come from a battery, generator, transformer secondary with the primary connected to an inverter sourced by storage batteries - it does not matter,) then I have NOT contradicted myself. I have been entirely consistent.
There is nothing wrong with thinking the way that you are, but when you state that other views are wrong, well, that is when you are wrong.
Well that's a heck of an intelligent statement. You've just got done telling me that I was "wrong" when I said that I hope I have made my point more clear. You told me I was "wrong" because I have unwittingly "undermined" Thevenin (even though I haven't.) You told me I was "wrong" because I have "contradicted" myself regarding the difference between "potential source" and "voltage drop" (although I have clearly NOT contradicted myself.) Why is it wrong to state that others views are wrong? That is known as "debate." If we cannot debate opposing views, then we may as well just give up trying to learn, fall in line and follow unquestioningly what Big Brother tells us.
If someone tells me that the sun rises in the west and sets in the east, then it is NOT WRONG of me to tell him/her that he/she is wrong, and to try to explain to that person why he/she is wrong. I CANNOT and WILL NOT subscribe to this point of view.
