mivey
fair question...Please, PLEASE show me one example in all of these posts where I have made such an argument...
Stop that. Criticize what was said, not the one who said it.You, sir, are a cur.
Mivey, I enjoy the zeal that you put into your posts, as evidenced your use of smilies. I think "confused" is good here, because it would appear that we are confusing each other. Let me try explain from top to bottom, as I must not be making myself clear. Crossman gary described (in post 167) a circuit made from a closed loop of zero resistance wire, with no potential source applied. He then made the argument that Ohm's law fails to predict that there is zero current flowing in the loop because I=V/R ---> I=0/0 which is indeterminable. Thus, your statement and his statement followed that ohm's law could not be used to say that there will be zero current...Originally Posted by mivey
But my point was that Ohm's Law could not be used to say that there will be zero current on the closed superconductor loop.
Agreed. There would be zero value in that.:grin:For known values of V=0, R=0 and I=0, it is pointless to apply Ohm's Law.
I'd either suggest giving up on the "zero-ohm" circuit theory discussions, as in the present forms they are simply not appropriate,
Unfortunately, I must say that I'm just a little bit disturbed this discussion has gone on here like this for so long...
Thanks for the input. I'm just wondering whether ohm's law is valid for theoretical zero resistance conductors and superconductors. These are certainly valid questions, and non-disturbing questions at that.
Could you answer two questions?
Question 1: Does ohm's law accurately predict current flow in a theoretical zero ohm conductor? (a "yes" or "no" answer would be fine, but if you need to elaborate, please feel free)
Question 2: Does ohm's law accurately predict current flow in a superconductor? (same as above on the "yes" or "no")
Like I said, if the model fails, make one that works.I think this is getting "just a bit" out of hand. Please consider two things:
1. Circuit theory is not a math field (if your looking for a good one, try Fourier transforms) - its purpose is to predict real world circuit behavior. If it doesn't, it isn't being used appropriately.
What value will that bring to the current discussion? IMO, a zero ohm resistor works fine for what we are discussing. I fail to see why you think it is an inappropriate model given the current scope.2. The corresponding circuit theory element for a superconductor is NOT a zero ohm resistor! (the "real world" just isn't that simple)...I'd either suggest giving up on the "zero-ohm" circuit theory discussions, as in the present forms they are simply not appropriate, or go and re-read your E&M field theory and then actually learn how a superconductor behaves, and then resume discussions...
Are you disturbed by the posters taking so long to finish their discussion or are you disturbed because we are not using some non-relevant (IMO for the moment) superconductor model? I don't see how the complex superconductor model will simplify our discussion.Unfortunately, I must say that I'm just a little bit disturbed this discussion has gone on here like this for so long...
It is a long thread but imagine if you were sitting around with your colleagues just talking over some things, it would not really be that long. Most topics are straight to the point "how many X's are needed to do y". Some are more thought provoking and lead to longer discussions. Probably equivalent to sitting around the grill talking about non-billable stuff while the burgers are cooking.Absolutely - it's that this has gone 300+ posts that is disturbing (the "for this long" part).
A simple representation of a superconductor consists of a normal resistor with normal electrons in parallel with a zero ohm resistor with superconducting electrons which appear when you reach the critical temperature. It does not address the finer points of superconductors like current limits, reactions to magnetic fields, etc., but certainly covers our simple discussion....The closest thing - superconductors - are not able to be accurately modeled as a "zero ohm" resistor, as their models are much more complex.
I would say no.I'll take your reference to "Ohm's law" to mean "circuit theory" in general (otherwise I'd say, no - as "Ohm's law" doesn't contemplate non-linear effects"), and say "maybe".
Hence part of the issue I have with the ongoing discussion of "zero ohm" resistances - they don't exist in the "real world" and fall outside of what circuit theory is applicable to.
However, when the dominating circuit elements of the model being analyzed have a "zero" resistance, circuit theory breaks down as there isn't any such "real world" system that can be described such a model.
From the document: Ohm's Law= The current through a conductor is proportional to the voltage applied across it : I = V/R090715-0921 EST
An interesting article:
"The IRE Student Quarterly", Sept 1954
"125 Years of Ohm's Law", by Henry Berring.
Google does not find this.
The Google result from --- 125 years of ohm's law berring --- is:
http://ieeexplore.ieee.org/Xplore/d...on=-134&arnumber=4321401&productsMatched=null
I do not have access to this and thus I do not know its content.
