nafis
- Palestine,tx
hi every body
this is what i have 240/120 services for hair salon , about 10 cricuit of 42 is not working and there is 0 volts reading on the breaker. the rest of the breaker works with load running fine with proper volt. i know the AC is not working and the voltage rating on it is 240 . the rest of the breaker is 120 for light and receptacle . i came to the conclusion the AC breaker is bad or one leg got shorted and shorted the rest of the 120V. can you guys suggest any other issues i might have overlooked. i noticed some flourescent lights will flicker then go off and the candescent lights come on for few seconds, dim then go off.
your suggestion is highly requested thank you.
thank you
thank you
