erickench
- Brooklyn, NY
I looked at the above section NEC and could not believe my eyes. It states the following:
(5) Run in Straight Line. The grounding conductor shall be run to the grounding electrode in as straight a line as practicable.
In Mike Holt's "Understanding the NEC" an Author's Comment following this section state's:
Lightning doesn't like to travel around corners or through the loops, which is why the grounding conductor must be run as straight as possible.
This is nonsense! When lightning strikes a conductor it becomes current traveling through a wire. It follows the path of least resistance which in this case is the conductor. It does'nt jump from the wire when it makes a turn. I don't know why they put this in the NEC. It does'nt make a bit of sense.
