- Windsor, CO NEC: 2023
- Hospital Master Electrician
Looks just like my parents' neighbor's garage subpanel. URD piped into the building, and then run wild into separate KOs in the panel.
Was going to say at least the panel was secured in place.....But I can't see a single mounting screw. How's that "thing" fastened?
Wait...look at the close-up...there's one roofing nail, sunk in not very deeply, helping the brick hold the panel up!
...crud...Pierre's sharp eyes and fast typing beat me!
Title is "Spot the Violations....". The idea is to list the violations.
"You were expecting maybe Humphrey Bogart?" :grin:
Would y'all believe that even with the bottom 2-pole breaker off, everything in the house still works?
QUOTE]
Changed this as I didn't see "bottom breaker"
Isn't the top breaker the Main disconnect, if so then I would assume the bottom breaker feeds a dead ended/hidden circuit
