mike mcswain
New member
- tallahassee
I reccently had a customer complain that the wire we used was not rated for 60 amps it was #6 seu al. I understand you have to go by the lug rating for correct fuse size but that doesn't change what the ampacity of the conducter is rated for does it ? This is on an a/c compressor that has a min. cir. amp. of 37.4 and a max fuse size of 60 amps so shouldn't # 6 al. be sufficiant enough with a 60 amp breaker ?
