Pic - 100HP Motor Failure
eric9822
Camarillo, CA
Electrical and Instrumentation Tech
100HP 3600RPM motor with a belt driven load that ran for about a week with little or no lubrication in the bearings.
To me it looks like a case of the OCPD set improperly. If set right you should never get motor damage. I bet the breaker tripped at some point from the increased current drawn by the increased friction of the bearings drying out and the electician just turned up the trip setting allowing for the motor to run to failure. Classic case of improper device settings and/or unqualified personel adjusting OCPD's.
