eric9822
 - Camarillo, CA
 - Electrical and Instrumentation Tech
100HP 3600RPM motor with a belt driven load that ran for about a week with little or no lubrication in the bearings.
	You can tell this from the picture.Looks like the belts were too tight!
I was thinking the same - the tight belts helped cook out what little lube there was - and the thing just kept going for long enough to melt the shaft.Looks like the belts were too tight!
Cool! An angle-drive motor!
Cool! An angle-drive motor!![]()
Originate, don't imitate!Are you sure this is not an "angle drive" motor???![]()
That be one of those flexible drive motors with a Wobble shaftOriginate, don't imitate!![]()
That be one of those flexible drive motors with a Wobble shaft![]()
Don't discourage your fans. After all, imitation is the sincerest form of flattery. :grin:Originate, don't imitate!![]()
