I'm with Steve on this one. I found about 10 corrections in an attic the other day and the guy straight up told me, "I didn't think you would go up there."
As true as that may be most of the time doubt I'd ever actually say it out loud. :grin:
An AHJ on a roof? I think I have seen that exactly once in my life. :grin:
So, in areas that inspectors may not get to means that following the codes in not applicable?
Those kind of comments always stoke my coals...if you get what I am saying.
. . . Course here not much freezes to deal with so this might be a post only for sensible localities....
If a "Electrician" said that to me, I would have quickly pulled out the
"Fine-Toothed Comb!"
The "Sleeper's" I use are similar to Iwires but are heavy rubber,uni-strut on
top, and have slanted yellow lines on the sides. For the life of me I can't remember the name of the manufacture right now.
Are the Blocks used to support conduits that are run across a flat roof required to be secured to the roof ? I've seen several instances where conduits were strapped to 4x4 treated blocks that were just layed on the roof that had been kicked around and crooked.
I've never seen them under a house crawling around.
Oh it was a "very fine-toothed comb". They pulled in a black #8 and used it as a neutral. "OK we'll tape it at both ends." "No you'll pull it out and replace it like the code says." (Normally I probably would have let them tape it.)
What code requirement are you referring to here?
I managed to get the Chief Inspector (a friend of mine) into a crawl space to inspect a furnace I hooked up. He was filling in for the regular inspector who was on vacation. He showed up in dress clothes and I started teasing him, taunting him actually, about going under the house where the rabid (and non-existent) raccoon lived. He got as far as the furnace and said I was OK. I asked if he checked ALL THE WAY back to where the Romex went up through the floor. You know, just in case I missed a staple. He just smiled and refused, noting that my use of an SSU was overkill. I gotta hand it to him for even going down there.
Would it be safe to say that a #6 or smaller grounding conductor could not be taped green also?
Thats very interesting about Identifying Neutrals and Grounds smaller than #6
with tape.
I learn something new every day.
on the good days, we all do. At my age even the "previous" stuff is often "new" View attachment 3771
with tape.
