I'm with Steve on this one. I found about 10 corrections in an attic the other day and the guy straight up told me, "I didn't think you would go up there."![]()
As true as that may be most of the time doubt I'd ever actually say it out loud. :grin:
An AHJ on a roof? I think I have seen that exactly once in my life. :grin:
So, in areas that inspectors may not get to means that following the codes in not applicable?
Those kind of comments always stoke my coals...if you get what I am saying.
. . . Course here not much freezes to deal with so this might be a post only for sensible localities....
If a "Electrician" said that to me, I would have quickly pulled out the
"Fine-Toothed Comb!"
The "Sleeper's" I use are similar to Iwires but are heavy rubber,uni-strut on
top, and have slanted yellow lines on the sides. For the life of me I can't remember the name of the manufacture right now.
Are the Blocks used to support conduits that are run across a flat roof required to be secured to the roof ? I've seen several instances where conduits were strapped to 4x4 treated blocks that were just layed on the roof that had been kicked around and crooked.
I've never seen them under a house crawling around.
Oh it was a "very fine-toothed comb". They pulled in a black #8 and used it as a neutral. "OK we'll tape it at both ends." "No you'll pull it out and replace it like the code says." (Normally I probably would have let them tape it.)
What code requirement are you referring to here?
I managed to get the Chief Inspector (a friend of mine) into a crawl space to inspect a furnace I hooked up. He was filling in for the regular inspector who was on vacation. He showed up in dress clothes and I started teasing him, taunting him actually, about going under the house where the rabid (and non-existent) raccoon lived. He got as far as the furnace and said I was OK. I asked if he checked ALL THE WAY back to where the Romex went up through the floor. You know, just in case I missed a staple. He just smiled and refused, noting that my use of an SSU was overkill. I gotta hand it to him for even going down there.
Would it be safe to say that a #6 or smaller grounding conductor could not be taped green also?
Thats very interesting about Identifying Neutrals and Grounds smaller than #6
with tape.
I learn something new every day.
on the good days, we all do. At my age even the "previous" stuff is often "new"View attachment 3771
with tape.
