two schools of thought on this. ....
Three, actually. He could 'cave in' and buy the customer a brand-spanking-new TV, and still has lost the customer.
Some people, when given a hundred-dollar bill, will complain it's not 5 twenties.
You did a service upgrade, did you cut your neutral first, and the hot conductors after that? Was the main in the off position and the meter pulled before any service drop conductors were cut? I'm sure the answer was no to the first question and yes to the second. If so tell her to something or other about flying rolling doughnut.....
Who's Sandy?
That would eliminate any funny business....a repair shop of YOUR choosing...
Good luck getting that in the air.:grin:Personally, I'd choose my garage :grin:
there aren't any MWBC in the house
I agree. And before anybody reads the rest of this posting, let me assert that I believe that under no circumstances would I consider you to be at fault, and that I believe you do not owe her anything with regard to the TV issue.I just feel if i'm right then i'm right, and will give no concessions to her if I am right. I won't bow down to a con artist or a crook.
However, I will say that it is not impossible that the TV worked before you started, and it is known that the TV did not work after you were finished. The only things that happened in the interval had to do with your work. I infer that it is not impossible that some aspect of the work caused the failure. What aspect? My only guess is either the act of turning off power at the beginning, or the act of turning on power at the end. Of these, my money would be on the later.
PLEASE NOTE that I am not saying that this would have been any fault of yours, for I believe that you did everything correctly, and nobody would have done it better. What I am suggesting is that the failure could have been similar to that of a blown light bulb. When do light bulbs fail? From my observation, 99% of light bulbs fail at the moment you try to turn them on. It is the surge of applied power that turns a nearly-dead-anyway bulb into a fully-dead bulb. In other words, if the day before you showed up at the house, a person (just for the pure fun of it) opened the breaker that feeds the TV's receptacle, and then closed it again, that may have caused the TV to fail.
Possible lesson learned: Recommend to future customers for whom you are performing work that requires a whole house power outage that they first turn off all electronic equipment, unplug all of it from the wall outlets, and not plug it back in until your work is done.
I have found that there is not enough preparing in the world, they will always surprise you.but I always try to be prepared for other peoples' stupidity.
This solves the problem of getting paid, having an unhappy customer who will likely cost you more in negative speaking than (loss of even one job?) and putting the matter to rest so your time can get to more productive issues. Be sure to get a signed release for damages. Scripture tells us it's the little foxes that eats the grapes. this can be equated to that the little things destroys a business or us as individuals. It's not fair, but it's logical to move on.
......480, send me 20 fives. I will not complain![]()
Sorry, fresh out of fives. Will 25 fours do?
With that in mind, and the fact that she told me that all of her TV's stay on 24 hours a day,
But this was my second visit, and neither time did I see the TV on.
Well, you could certainly use the threat as ammunition, but you should know whether you can first. We have a cost-of-collection clause in our contract which specifies an interest rate and all legal costs.For instance, if we're in court for 4 hours, I could have made $260 taking calls in that same amount of time. Could I countersue for that?
We asked him to remove the items from the shelf. he told the guy that all of the stuff on that shelf had to be removed.
I know the customer was wrong and we were right. The $100 was nothing but good will.
Maybe you better disconect their power for "safety" reasons until you get to the bottom of this.
