charlietuna
Does the washer need to be on a GFIC protected circuit?  Thanks
			As Chris stated no or yes. In a finished room no in an unfinished basement yes, in NJ probably no in either.
Thats not what the NEC says?
Finished or not, if it is 6' from a sink, it will be required.
See 210.8(A)(7) "2005-2008"
I guess he forgot the whole story OOPs.That's true, but I didn't see the word sink in the OP.![]()
I did not see basement in there either. :grin:
I have also seen them in garages, sheds, kitchens and outside under overhangs. Just because you have a working washer does not mean you have a laundry room.
I think that we should start over and delete every post after #2.
Chris had all of the information in that post. Bottom line is we can't directly respond to the OP without some more information from Charlietuna.![]()
I think that we should start over and delete every post after #2.![]()
actually post 3 had it summed up.![]()
Not a bad idea. :grin::grin:
