Does wash machine require GFIC protection?
As Chris stated no or yes. In a finished room no in an unfinished basement yes, in NJ probably no in either.
I have also seen them in garages, sheds, kitchens and outside under overhangs. Just because you have a working washer does not mean you have a laundry room.
I think that we should start over and delete every post after #2. ;)
Chris had all of the information in that post. Bottom line is we can't directly respond to the OP without some more information from Charlietuna. :)
GFCI protection is for receptacles, requirement is by location, IE where the receptacle is.
A washing machine does not by itself require GFCI protection.
