Jerseydaze
Are we required to install afci on existing circuits with a service upgrade or does this fall under rehab code? In Jersey
Today, 06:40 AM
Today, 07:48 AM
Anyone?????
Just wondering, how they missed covering that on your last CE class. The main idea of running the CE classes was to keep everyone current on all changes.
If you are doing a service upgrade you are not required to install AFCI breakers. However, if you are wiring say a bedroom addition where NEW circuits are installed you will be required to install AFCI's. If you have a situation where there is an existing breaker panel in the residence that does not accept AFCI's you will have to install a sub-panel that does accept them.
Once again. You have to think this thru. If you have MWBC's you cannot install AFC's. They can't make you rewire the house to do a service upgrade.
If your putting on an addition, I am sure you are not going to use multi wire circuits.
