Well go take one so we can see it.My 'tree' is the best Romex tool I own.
Sorry, no pic,...
I've never used a rack for small romex. When using a small coil, I always grab the #coils I estimate I need, then walk out the curl and start pulling. I can see it would be handy if you could make a non-stop pull, but I invariably wind up having to go around something to keep from getting snagged. If there were oodles of runs taking the same path, I suppose you could nail in some boards to help feed the cable (works great near the panel) but I'm not sure it would save much over pulling from multiple coils.I like the Carlon wire dispenser.
http://www.carlon.com/Master Catalog/Wire_Handling_Products_Brochure.pdf
See page 3 for the WK7203
I got mine for about $50 from the supply house.
Which work great on UF, by the way.
Always strip wire before you put it into the box
I never used the stud bracket. The floor bracket works for me on everything.
If you're going to be working in romex, just buy 1000' spools.
It's not so much about blindly sticking your knife in the box. Just get it started and zip the romex apart. You still have to trim the shield & filler though.That's how I learned and still do it. Some time in the early 80's, production workers started stripping the sheath inside the box. I can see how it may be faster but never liked blindly sticking my razor knife in there, especially with 3 wire.
Seriously. Just place the cable and squeeze, relax very slightly, and push on the stripper with the thumb of the hand holding the cable.Seriously?
I would if they'd sell it for appreciably less per foot. Otherwise, it's not worth carrying it around. Using up remnants isn't difficult.If you're going to be working in romex, just buy 1000' spools.
I would if they'd sell it for appreciably less per foot. Otherwise, it's not worth carrying it around. ..........
Absolutely agree. I also "reverse" wire, feeding toward the box I'm maling up instead of away from it. I can rope a receptacle circuit and end up with only the shortened EGC wires as scrap.Seems faster to me to strip before putting in the box.
...I would be ashamed to lasso wire around my head.
Hmm. On the next big house, I'll consider it. I don't have the room or weight capacity in the van to carry around six 100' spools.Then don't carry them around. I back up the the garage, and set them up right on the slab.
Without coiling up like 250' rolls, I can pull it clear across the house to the other end without snagging it on anything, so I'm not carrying 3 spools all over the house.... they all stay out in the garage.
I do that, too. I pull out about what I think I'll need, and unwind it from there back toward the end, spinning it, not overhead, but out to the side, like the rodeo cowboy who jumps in and out of the spinning lariat.No shame in my game. Like the others said, for short runs of MC (and I suppose NM), this unwinding trick works pretty good.
