mcclary's electrical
- VA
I do that, too. I pull out about what I think I'll need, and unwind it from there back toward the end, spinning it, not overhead, but out to the side, like the rodeo cowboy who jumps in and out of the spinning lariat.
It's a little less violent.![]()
...........Added: You still gotta lug them around and into and out of the van.
Always strip wire before you put it into the box.
The new Sit & Spin wire dispenser Goldstar-1 model.:grin: Laugh if you want to but it works and doesn't jam up. I saw it on the side of the road on garbage day, hit the brakes and picked it up, made a slight modification by adding some 1/2" plywood to the bottom and "Voilla". You can go to the supply house and spend $140.00 on a Racketeers model. I don't look for prestige on the job - just looking to get it done.![]()
Classic...I love it. Im going to my cousins 5th birthday party this sat. Guess what Ill be looking for......![]()
No. I originally used this with a roll of 12/2 MC cable. It worked fine up until the last 20'. Then the Sit & Spin started to creep. I added the plywood so that I can either nail it to a plywood floor or situate the unit behind an open studded wall so it doesn't creep. For me there's not much set-up involved. Take the Sit & Spin out of the shed, bring it to the job, drop it on the floor and put a roll of wire on it and go. No mounting to studs. It doesn't take up much room, no one is going to steal it (for rear of embarrassment - but I'm beyond that) and if they did there's no great loss other than the convenience - but I'll find another one.Is the 1/2" plywood to add weight to the Sit-N-Spin?
Hi again
Just checking out some tools for romex installation and I know some of you have been doing romex your whole career so I thought Id see what you recommend for strippers, cutters etc.
I have done a few hundred houses (as supervisor) with romex so I have a clue on what to use but Im lookin for some solid advice on quality and performance of these types of tools.
Actually any hints/tricks are also welcome in this thread.
Trade secret: Strong enough for a man, but made for a child. :grin:Trade secrete revealed, thanks.![]()
to wire houses for builders, all you need is a big pile of money. keep wiring houses until all the money is gone.
"The Law Of Negative Return": We are losing money on every job but we are going to make it up in volume.I hope you are referring to: "The Law Of Delayed Return"![]()
"The Law Of Negative Return": We are losing money on every job but we are going to make it up in volume.![]()
How do you guys move 1000 foot spools around the house easily.
How do you guys move 1000 foot spools around the house easily. We tried it once and it was slower than 5 guys pulling runs all over at the same time, and pulling multiple runs in at once (IE from the panel to upstairs). 1000 foot has proven to me only, too cumbersome. We can work faster with 4-250' rolls as oppose to 1-1000.
Both of these methods are time wasters, and I would be ashamed to lasso wire around my head. How can you do that in a house anyway? just my opinion. Lay a hand roll on the ground and spool off what you need in your hand, then walk it out. Always strip wire before you put it into the box. When you look into the box, I don't like to see more than 1/4" to 3/8" of sheath.
