LowSparkHighHealed
Hi, do I need to stay with IC rated recessed RI fixtures if I am constructing foam board isolation boxes to seal off from the batt insulation?
Larry one other question. If I am using the "remote transformer" type of recess rough in (which only has a junction box, no transformer) what is the customary wire type that is run on this low volt circuit? I assume any cl2 wire that is of the correct wire size for the load and distance will suffice but I was wondering what is customary. I am thinking cl2 speaker wire, but would the inspector allow typical outdoor extension cord for those runs? It sure is easy to work with and cheap too.
Looks like I am REALLY gonna have to get a code book, thanks. So are you saying only good ole romex (or conduit) for the low volt secondary wiring?
As far as I know? this has be a many of debates here on LV cabinet lighting.
do some searches on LV cabinet lighting here.
