big john
- Portland, ME
Just Use Type-F and BNC Adapters
So, a little update: I've gone through almost 70 Ideal 89-048 connectors to try and do what should've taken 32.
I took an inoperable crimped connector and cut it open. I found that if the coaxial is stripped 1/4" off the center conductor and 1/4" off the braid, when you push it into the connector the coaxial insulation reaches the stop inside the connector and the center conductor is barely making contact with anything!
I'm not sure what the heck Ideal was thinking, because those are the stripping recommendations on the package, but it's almost physically impossible for them to work that way!
I changed the strip lengths to about 3/8" and 3/8" and I've gotten slightly better success, maybe at about 75-85% work the first time out, but I'll tell you what: I am all done with Ideal compression connectors.
Not for the life of me will I ever use these again, and I hope someone reads this and maybe saves themselves the hassle. The next project I'm gonna go with the simple type-F crimps with the adapters.
Thanks for the help you guys gave me, and thanks for tolerating the rant.
-John
-John
